treebonker
- 100
- 15
- Aug 22, 2004
land of the mor,
Asia
You all know we have an issue with the standard ARP head stud washer and nut interfering with the valve spring. Most lay the washer before installing the head and just force the nut past the spring and let it strip past the spring seat. Well I did too until I saw what happened trying to figure out why the valve stem isn't parallel with the springs. While the spring seat cuts away at the nut the seat lifts off the floor binding the spring. WTF
I read about ARP's with a smaller nut. Is there a part number for the nut or are they sold as a set only? If I can get the nut I'd rather not cut the spring seat.
ARP 12mm studs w/ Supertech duals
pic-1: washer clears
pic-2: seat lifted (actually worse than shown)
pic-3: ahhhhhhhhhh
pic-3: ahhhhhhhhhh
