Arm for the actuator popped off of flapper on turbo
GSTurbo1
610
May 2, 2012
Pickens, SC, South Carolina
On my hahn 16g the actuator arm popped off of the flapper fitting for the turbo... could this be why my car takes so long to spool up? And the actuator will not move if i pull on it. Will only the pressure allow it to move?
what should I used to hold the actuator arm onto the flapper
Yes that is why. The WG actuator has a spring inside and when the arm is attached to the flapper, it will have preload to keep the flapper from being blown open. So take the arm off and now the flapper easily gets blown open and the exhaust gases bypass the turbine= hardly any spool/boost
The spring inside, I believe is around a 12lb spring and that is why you can't open it by pulling on it
The flapper shaft should have a pre-drilled hole, does it not? The arm should slip over the flapper shaft and you would then insert a small cotter pin to keep the arm from coming off
^ this.. also do a boost leak test.. if your having this many problems, odds are theres more. u should be building boost like at 23oo.. and full around 3200 or better.
Holy $h!t my car is too fast... and the turbo is more than plenty!!!! I hooked the arm onto the flapper took it for a drive and about nutted in my pants. LOL. I have been through about 8 crotch rockets and the feeling from that turbo spooling comes close to riding the bikes. I just rode with an rx7 and wrx sti and they were amazed at the difference. I can actually keep up!!!! Thanks to all, you guys are awesome. So close to having the car where I want it. I set the MBC to a little over ten... maybe 12 psi, probably a little less. Def time for some wider tires to get the front to stick. All I need to do is lean the hard load out a little on my map and we will be good to go. What do you guys try to keep your AFR close to under hard acceleration
no the lower the numbers is the leaner you are the higher means richer you may need bigger injectors and a tuning device
if your hitting 10 on the wideband then your to lean and need more fuel
:confused::ohdamn:
afr=air to fuel
10.0-1= 10 parts air to 1 part fuel
14.7-1= 14.7 parts air to 1 part fuel
higher the number the leaner the mix
:heystupid:
I got 450cc injectors and megasquirt extra with tuning program on my computer, you know that 10 is really really rich though right... do a little research. 15-18 is lean
:confused::ohdamn:
afr=air to fuel
:heystupid:
thats what im saying man... about made me question myself :confused: for a second. LOL. but then :aha:
we are all good though, just need to lean it out... cant wait to get it tuned perfectly now. I'm going to have a monster after tomorrow. About an hour tuning and we are going to be in business.
:hellyeah:
