Want to build off of the hahn's turbo kit
Eclipsracer1320
Sep 2, 2002
Springfield, Ohio
I have a 97 rs with the following mods, venom intake 65mm throttle body, mainfold, crower stage 3 cams with dual valve springs and retainers,5 angle head job ported and polished and everything the bottom end is stock. I was going to buy the stage 3 turbo kit for hahn that comes up some time this summer and i wanted to add a big 20g turbo from greddy or Hks or what are you thoughts on what i should add and yes i already know i have to build up my bottom end.
thank you
Jordan
My thoughts are, that you can get a 20G from Hahn. If you want another style turbo from Greddy/HKS etc then you have to make sure that they mount to the flange on your Hahn manifold. Hahn kits will not accept say a t3/t4 turbo because the flanges are different between the turbo and the manifold.
Why not just get the Hahn kit and then change small things that you may dislike, or can replace with a better unit. For example the Cartech FPR that comes with the Hahn kit is pretty much useless, so a lot of people change it out for a more reliable Vortech SFMU adjustable one. Another example would be the BOV. You get a stock 3000GT one that you can replace with a MUCH better and less leak prone aftermarket. Not to mention that it will sound much better.
Hahn's kit is great to have as a starting point. If you wanna get buck wild tho, people have done custom setups to their liking.
Search 2gnt.com if you have not already.
