Are these timing marks aligned correctly on a 2gB? And why am I having problems???
-DSM2NR-
602
12
Dec 9, 2005
Tucson, Arizona
I've lined my timing marks (when I was changing the timing belt) according to this picture. Are these lined up corrctly and the same for the 2gB?
Ever since I changed my belt my car has been hesitating and vigoriously shacking when I hit WOT.
At first, I checked the gap on my spark plugs. Perfect condition. Then, I thought it was a boost leak so I replaced my rubber intercooler pipes with some hard aluminium ones which didn't solve the problem............
WHAT'S WRONG:mad: ????????????????????
ya you got to make sure you check the cams because the valve springs like to push them over a bit once you take the belt off, if you want to, check out vfaq.com, its very helpfull
Everything is absolutly adjusted correctly. The pins (12o'clock), the cam gear marks (3 and 9 o'clock), and all the other timing marks.
I was just wondering whether the picture above is the same for 2gB's since it originally states that it's for the 2gA (95-96).
And, does anybody know if overboosting can cause this problem? Every since I replaced my shity 2g bov with a greddy type-rs (I replaced them at the same time I changed my belt) my boost has jumped up to 20psi. This is on stock fuel..........
Might this be causing the problem?
Yes, it drives normal at part throttle. It drives normal all the time unless I floor it and the boost kicks in. When the RPMs get to around 6000+ (on full boost) I hear a loud noice(misfire) and the car jerks back and forth............
what do you exactly mean by "blowing open" Is that when the bov doesn't depress after the air is sent to the intake?
And how can I check if it's blowing open anyways?
