Resolved Are 1g and 2g thermostat housings the same?
phillabaum03
849
3
Nov 28, 2005
sharpsville, Pennsylvania
I put a 2g head on a 6 bolt and i am using the 1g water pipe. This would make me use a 1g thermostat housing and i wanted to double check that it would fit on a 2 head. I was told it would. I know they are different looking, i just need to know if it will bolt up.
Nope... you'll have to use a 2g water pipe and a 2g T-stat housing. Totally different bolt pattern
2g Head
51749d1117195104-thermostat-housing-2g-head-what-hole-goes-into-head-resize-dsc01167.jpg
1g Head
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
