ARC-2 on a 1g?
Yes, I am using the 2g kit. I have had it for a year and a half now or so and it is the best ignition solution out there IMO.
If you indeed have a 91, the kit is plug and play except for the mounting bracket supplied with the kit.
Sweet, the mounting bracket is a seperate piece from the module itself, correct? Thanks:)
Yes it is bolted to the module with 4 screws. Its easy enough to keep the bracket on it and mount the whole thing up near the brake booster.
