kiggly
Supporting Vendor
- 326
- 223
- Feb 17, 2003
Ann Arbor,
Michigan
From what I've seen, low pressure drop appears more important than good cooling.
The ebay core may look nice and straight through, but it still has reasonably high pressure drop somehow. I changed from 2.5" to 3" piping, the intercooler, and to a Q45 throttle body and my pressure drop, end-end, went from ~3psi to low enough that I can't call off a number (sensor will accurately read 0.1psi differential).
I picked up 15% power at the same boost level with the new intercooler. The only change besides the intercooler and piping was I went up from a 1.1AR to a 1.25AR turbine housing. So far, I've only run it at about 17-18psi because I was fighting other issues. At this power level, the two turbine housings shouldn't make much difference at all.
Kevin
Kevin
I wonder if I could have my negative rep points taken away
