any ideas on what turbo to run on my build
95talontsiwv
Jan 22, 2010
stonewood, West Virginia
Hello , im building a 91 talon tsi awd, an was wondering what turbos size would work best on my setup.an give me the best power.
engine mods= eagle rods , 8.5:1 wiseco pistons, balance shaft elim. , mls head gasket, head studs, pte 880cc injectors, stock cams for now
suport mods== dsmlink v.3 , eprom ecu, 255fp, 3" gm maf, coil & plug, after market fuel reg, fmic , 2600 clutch ,
stock drive train.
Thank you again for all your opinions an advice. Car is running an tuneing is done for now may need little tweek her an there witch can be done the more i drive it . Didnt use 3" gm maf, or cop set up . Use 2g maf with greddy intake tube that cam on car. Running 23lbs of boost
again thanks to all.
I want to say thank you all for you input an advice, i ran the 20g for now becuse its what i had avalable at the price i could afford at the time. Its doing pretty good on my setup for now, keeps the mustang guys around here in ther place. Behind me LOL . Looking to put a hx35 on the car next since im back to work after breaking my arm last yr. I did the research on the imput you gave me .
