banishedmunk
- 1,054
- 24
- Jun 6, 2006
Miramar,
California
sure will as long as you have everything I need for the swap. engine swaps aren't free though so it may cost you a bit of green
...and he doesn't mean the kind you smoke.sure will as long as you have everything I need for the swap. engine swaps aren't free though so it may cost you a bit of green
...and he doesn't mean the kind you smoke.![]()
Kris, I took the head down to the machine shop today to get it decked, cleaned, valve job, and bronze valve guides pressed in. He said turn around was about 3 days so it looks like I'll have an extra week to get everything ready to do the install since you'll be on leave. I still can't decide between the composite or MLS hg...
Aem uego
Yea, everythings there. It's just a 1-1 swap with another 7 bolt. only thing that really needs to be taken off the old and put on the new is the cam angle sensor. And name your price, I'm sure it's better than satan... I mean the Mitsubishi dealer.
Chuck, did anyone ever tell you that you have 21 chromosomes?I'm not that smart to do that
I also tap into the ignition harness. My turbo timer is powered through there (obviously) as are my AEM wideband and tru-boost gauges....I always tap into the main ignition wire in the steering column but thats me.
Well whatever your I.Q. is I was just joking, who knows though you might still have 21 chromosomes and don't know it.People like because I'm polite and rarely late, later a doctor will tell me I have an IQ of 46, wich some people would say that I'm mentaly retarded
2g wire colors are probably different but basically you pull out your cigarette lighter and with a DMM (digital multimeter) test the voltage readings with the key in the "ON" position. The one that shows 12VDC is the one you tap into for the red power wire off the WB. To check the ground you move the switch on the DMM to check resistance (it looks like an upside down U with feet). Touch the chassis of car with one meter lead and the other on the black wire going to the back of the cig lighter. If the DMM shows a ZERO then its a good ground...It's just a qoute from a movie....how
exactly dis u hook up to ## cig
lighter
