Any Advise For A 4G63 Build??
DsmChic19
Sep 25, 2007
Bayonne, New Jersey
Ok well I decided(with the help of people on here) to build up my 95 Eclipse GS-T with a 4G63 motor. Does anyone have any advise for parts that are better than others?? Is a certain turbo better than others, ect. Also anyone know what a good set up is??:dsm:
Try to stick to OEM (Made by Mitsubishi) parts whenever possible, especially avoid cheap gaskets and timing belt parts. Your goals will determine what parts to upgrade. Stock parts can hold a lot of power. A stock rebuild with an Evo 3 turbo setup and some supporting mods will easily produce over 300 whp and make a reliable, quick daily driver.
And if you want to be cheap... look at partsdinosaur.com
I bought the timing kit about 3k miles ago and it is working great. My mitsu timing kit had the water pump bearing failing after 15 k miles (it was an AISIN pump from the dealership). I'm just stating this as an alternative.
What is the condition of your current 4g63? have you done a compression test?
