Another Ignition Timing question
techghost
196
Feb 8, 2009
Karachi, Asia
Guys,
i've just checked the cam gear timings as well as crank pully. everything is aligned. I've also adjusted the CAS with timing gun to align timing and its all good now.
Just noticed, now the idle vaccum is around 16/18Hg which was 20 before (when CAS timing was off) and at idle on DSMLink log i'm seeing around 10/11 degree Ignition timing (with all sliders 0'd)
Any reason why timing is soooo low and vaccum as well?
Isnt 17/18 vaccum low for a stock motor ? What about the timing everyone sees on their link when idleing? I thought I should see 15 or more
Guys,
I live right at about sea level. Before my cam swap to 264/272s, my vacuum levels were the same as what you are seeing- 18 in Hg. Timing at idle was also around 10 degrees BTDC. I don't see anything wrong with what you described.
Idle speed can affect the vacuum level a little. If it's low, your vacuum can dip a little and if it's high, you vacuum level can increase slightly. With my cams and an idle set at 900 rpm, my vacuum level is about 12 in HG and the car runs and idles fine.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
