Another Engine Clean up Project/Fusebox Relocation
Summit Racing Part # AER-FBM1532
First i used these to cut the line off and the other end of the sending unit. the parts that has the o-ring/seals for the fuel pump.
Not sure what size drill bit, just used a small one with the rotozip to enlarge to hole to fit the fitting in
Looks good Richard. I need A/C though, it's impossible without it.
ROFL... so does every girl ive dated since ive owned this car, helps me save gas during the day since we end up using "their" car :sneaky:
with the added vibration from solid mounts, noise from open Downpipe/Cams... ill be lucky to live up to my spark plug cover :cry::cry:
Everything look sgood. Your car looks like the one I parted out LoL.
I have to admit it's fun taking things about and seeing ho wthey work but I hate wires. Good luck with everything. *subscribed*
BAH! come up here for a couple of days this winter... You'll find out what cold really is :p
And while your up here, you could relocate my fuse box for me!:sneaky:
that's gunna be sick after your done. You should do a write-up for the fuse box relocation
ROFL Never again will i touch another fuse box :sosad:...
Ill definetly do a write up however, i took enough pics for it so if everything goes well ill start on it:thumb:
Maybe that could be a good reason for me to go ahead and pull my A/C... I never thought of all the secondary benefits of no air! :D
Screw that, I never use my A/C.... but I sure as hell did when I was stationed there.
On topic though, I've been thinking about doing this for a long time. I'm still gonna have my engine out for a couple months, at least till I get my srb installment. If I ever get my garage cleaned up, I might have to take this project on.
DAY 29-31
My motor mounts from biglady112 finally came in :D off to get powdercoated... Along with that came in the FIC 950cc and HKS 272/272 Cams
I also checked with ct78155 on the powdercoating and heres a teaser :p
I installed all the fuel lines and fuel filter
Installed the cams and 3g Lifters (Yup i was pretty generous with the Assembley Lube)
Whlie putting in the CAS i found out that for 97-99 you have to drill and tap the Intake Cam for the CAS 12mm bolt to screw in.. great...
Then i started thinking, i have a 1g CAS laying around, why not just use it? I did some research and it seems as though all thats necessary is the Harness that uses the Crank sensor and CAS to power up the 1g CAS (THanks to flash for pointing this out but NO didnt wire this, it was given to me like this)
Im using this page to help me make the harness instead of paying $75 for one :sneaky:
RRE Instructions
Looks great. I can't wait to see the final product. Now I just need to get you pictures of my ride.
DAY 34-35
Final shipment from ExtremePsi came in :D
Finished Mounting up the Fuel Filter and just mounted the New Fuel Pressure Regulator that came in
So now im Finally ready to start putting everything back together but first time to remove the balance shafts
Knocked out the old bearings for the new ones
Replaced the Seals and Pluged up the balace sprocket hole, i also JB Welded the back of it just to be safe from oil leaks
I used "Right Stuff" on the Oil Pump to prevent leaks
Put back the strainer/oil pan
Flipped the block over to put back the Alternator/Water Pump/ etc
I put on the new JM Fab Coil Pack relocation bracket and it works great! Out of the way and very convenient
Sprayed Copper Spray on the headgasket and torqued it down to 86lbs
Now im just waiting on the JM Fab SMIM, Powdercoats/chroming to be done so i can finish putting everything back in the bay :thumb:...
Yea i have one but its being occupied by my 6 Bolt Build :cry:
Either way i was ALWAYS careful to never scratch the block and layer the floor where it layed
DAY 29-31
RRE Instructions
Redo the wiring on that please. Solder it the right way (many people actually suck at this and really don't know how to solder, amazing eh?) and then get some heat shrink.
If you want to take it a step further, then do fully sheathed, military spec Raychem DR-25 heat shrink. Then it would be absolutely gorgeous!!! :thumb:
Raychem DR-25 heat shrink: Diesel Resistant Heat Shrink : BuyHeatShrink.com : Adhesive Heat Shrink
