Another Engine Clean up Project/Fusebox Relocation
Hey guys, if you guys wanna catch my follow ups, im now moving on to help my friend out on his project. So this time ill be doing a wire tuck on a 1g with alot more info/pics.
Heres the thread in the "Project/Build Section"
http://www.dsmtuners.com/forums/pro...-cleanup-rebuild-wire-tuck.html#post151629735
Heres the blog:
http://www.dsmtuners.com/forums/blogs/dsm_pwr/395-yet-another-engine-cleanup-rebuild-wire-tuck.html
Heres the to-do-list
*Wire tuck/rewire
*Rebulid Bottom End
*Remove ABS
*much more..
Heres a small preview ;)
Bringing this back from the dead... What did you have to do to make your ssac uicp line up with the Jm SMIM?
I had to cut it a pretty extensive amount, it barely cleared the motor mount and a tbolt clamp barely clamped on. Once i started boosting, the pipe kept blowing off so i ended up taking it to my welder and he made a new tb elbow to clear over the motor mount
Alright, thanks.. I'll just save the trouble and weld my own elbow.
I noticed a lot of people have had issues with the lines on the fuel pump assembly just wanted to show you guys what TAB Fabrication did for a friend of mine.
Are you asking about the wires? I didnt have to lengthen much mainly shorten ALOT of them, and if i did have to make a few longer, i re-used whatever i cut off (which wasnt much)
That before and after picture is nuts, great job man it looks great.
I'm not sure if its the camera or what but ya might wanna get some beads on those intercooler pipes. You can bring them to any exhaust shop or even use your favorite welding alternative (jb weld :D )
Any, the hard work definitely paid off, thats one of the cleanest bays I've seen in a while.
man i just read threw every page of this.... you did an absolutely beautiful job. i love the purple color sheme it looks tight. great job man.
can you pm i need help with a 1G wire tuck
What did he charge to do that? I may want to have it done, he has done some work for me already.
