Another Engine Clean up Project/Fusebox Relocation
ct78155 sold me cracked up sideskirts. :toobad:
I like your thread. Good luck on finishing.
Thanks! sorry to hear that, he's a good friend of mine and i havent known him to rip ppl off..
Really? I've heard nothing but good things from him. I have bought a bunch of things off of him. And i will continue to. He's upfront and even takes pics for me to show progress. Must have been a bad day.
James :laser::talon:
Yup :thumb: ima have him powdercoat a few things and you'll see them throught the progress....
I can't wait to see the finish look i really want to do this aswell but i'm just not the best when it comes to electrical stuff.
Its not that hard, you just have to have ALOT of patience and planning:)
Yea, I called him out on the crack and he said it wasn't. Southern Mexas sucks LOL He powdercoats in his backyard LOL
I dunno. He says he has a shop. He just got a new oven that is 4ft by 4ft. So he does a lot more now. He even does ceramic coatings now!
ROFL LOL yea when he first started out... now its like 2 years later and his buisness has really grown, he's moving on to ceramic coating and soon painting cars, he's gunna be the one to paint mine:cool:
LOL well good he's moving along with business LOL Still screwed me on my skirts! I demand partial refund! LOL
Sorry for the thread hijack. Got any updates?
Wasn't a bad day James, here is the feedback that this guy gave me when he received the sideskirts:
http://www.dsmtuners.com/forums/itrader_detail.php?ir=6948&u=76368
I've got 100+ positive feedbacks on ebay and only 1 negative, which was resolved. Feedback on here, dsmtalk, and dsmtrader is ALL positive.
Maybe it's just me, but if I received damaged parts I would have filed a complaint with paypal and left negative feedback for that person......
Got pics of that head from Wess yet James????
LOL it wasn't even in a box. It was wrapped with plastic, not even bubble wrap hahahaha It's cool.
Update: Got all the timing/manifolds/water lines off the block, cleaned up the engine bay a little, and removed the ECU harness and rewired it.
BEST TOOL EVER!!
I took off all the wire loom and tape off and man it was definitely sticky...
Here’s all the unnecessary connectors from the ECU harness
I finished up the ECU harness by removing all these sensors/connectors and i rewired the Power Transistor/injector resistor box to the lower end of the harness (Inside the Car)
* Manifold Differential Pressure (MDP) sensor
* Auto-Cruise Control Vacuum Pump (Cruise Control Actuator)
* Fuel Pressure Solenoid (FPS) Valve
* Exhaust Gas Recirculation (EGR) Control Solenoid
* Brake Fluid Level Switch
* Theft Alarm Horn
* Turbocharger Waste Gate Solenoid Valve [Boost Control Solenoid (BCS)]
* EVAP Emission Purge Control Solenoid Valve
* Air Conditioning (A/C) Compressor
* Fuel Pump Check Connector
Dam dude you have patience, too many wires for me. Definitely going to look alot cleaner now......
DAY 19
Sorry things have been a little slow, I shipped out my Front and rear motor mounts to biglady112 for this http://www.dsmtuners.com/forums/bolt-tech/289588-solid-front-rear-aluminum-motor-mounts.html
Still waiting on the HKS Cams 272/272, FIC 950cc, and Solid Motor mounts to arrive :thumb:
This week i gunna order the rest of the remaining parts like the JM Fab SMIM, BSE Kit, and etc
My sister had the camera for a while so i didnt get to get all pics of progress so far but this is the update:
Some parts that came in so far:
DSMLink
3g Lifters
STM Fuel Filter kit
Some stuff ima send out to get powdercoated this week (Big thanks to hdoerr for knocking out the stock rubber out the motor mounts!)
Gotta love JB Weld for those Coolant lines to the TB nipples :D
Some stuff ima send out to get chromed next week
Heres a small portion of weight reduction ive taken out (more to come soon!)
Cleaned up the tranny a bit
More color matching :D
I started taking out the balance shaft to install the kit once it arrives
I installed back the fuse box harness and routed it ina way that your only gunna be able to see this small portion of the harness, either way a pretty clean look IMO
Today im planning on taking out the stock fuel lines and the windshield wiper fluid reservoir and all the components
Just looking for stuff for weight reduction
Success
DAY 24
Got some parts in from Summit Racing :D
Instead of just threading in the -6an fitting to the stock pump assembly, i decided to go straight to the source :sneaky:
Dont worry ima seal the hole so gas wont leak.
Also finished up the battery relocation kit
Decided to put the Fusebox in the glovebox because there wasnt any room because of the HVAC :(
I finally dropped of stuff to get powdercoat and chrome yesterday and i started looking at the bay and wondered if the brake lines would look ugly :toobad: so...
I got some Hi-Temp Chrome paint and polished up afterwords
LOL ^
I live in Central Florida and I cant live without heater either or I wouldve taken mines out.
40-50 degs can be cold in the mourning and at night, especially when its 70-80 in the daytime and it catches you off guard. LOL
Yea i never really wanted to remove it but my friend with a 1g FINALLY convinced me to do it...
then i found out they dont make Manual Racks for 2g :cry:
At least it will look clean :confused:
Lol, yeah its not bad on a 1g but a 2g your going to be building some muscles up now LOL.
What is the part number for the fuel fitting you got from Summit off of your sending unit? I snapped my line there so I need to drill that and run braided up to my filter. What size drill did you use to? Did you have to thread it? I take it your going to JB-weld that SOB on there for no leaks?
