Another disaengaging thread
OnABudget
42
Jul 21, 2004
Bay Area, California
I read the other threads, but I'm not sure i have the same problem. When the engine is off and I press the clutch pedal, I feel resistance and the pedal comes back fine. However, when the engine is running, the clutch pedal goes in too easily and only comes back up halfway. This obviously makes it impossible to disengage the clutch and put the car in gear. The odd thing is that it works while off, but it stops working as soon as the engine is running. I recently replaced the old slave cylinder (which was leaking) with a new one.
Thanks for the help
:cry:
stop complaining, your car is hecka fast. :D
try cracking the banjo bolt loose and bleeding the clutch again after that.
Nop, this didn't do it. Adjusted the master clutch cylinder and now it's a bit better. The car is driveable but it grinds 3rd gear. What do you suggest?
