alternator relocation
pnklmnd
491
Jul 21, 2004
reno, Nevada
i want to know where you can purchase the alternator relocation kit.... It relocates it to where the AC pump go's....i want/need one!
More room for turbo, piping, exhaust, one of these... :sneaky:
Jay
I've also been looking into doing this, as my intercooler piping runs right into my alt. the Buschur kit goes for about $180, but I've heard the belt that comes with it doesnt fit very well, I could be wrong, it is just something I have heard. Also there is another place that I am sure sells this kit also. It's called DENT motorsports, I think their website is DENTsport.com. so anyone have any reveiws about how much of a pain in the ass the relocation is, I'm sure you have to lengthen the wiring, correct?
If you're running an electric water pump, the belt works fine, as the kit assumes that you've got a water pump delete plate. You'll also need to cut a portion of the cast motor mount for belt clearance if using the stock water pump on a 1g. Not sure about the 2g's.
I'd recommend saving your money for something that actually provides a tangible benefit unless your setup absolutely requires this.
would the alternator be able to be replaced w/out pulling the motor with one of these kits? i know the AC compressor was a bi*** to squeeze out from under there, just wondering if the alternator would be any easier. Thanks
-Ryan
Well the way i want to run my exhaust it needs that space.
Im just going to run my wastgate dump out the side of my front bumper as opposed to the outlet and the wastegate dump.
