Spoolin4Ever
- 1,142
- 14
- Apr 24, 2005
Moses Lake,
Washington
Is that pretty much normal that if the alternator is only putting out 12.8 volts the battery only lasts about a day and I got to hook it up to the charger again?
Battery tests good but it's a walmart battery testing it at walmart so not sure if they are testing it right. I got another alternator on the way, so this is just in the meantime...
Hooking up a multimeter to the battery posts, it and car running says 12.8 volts...and they should be giving me 14 volts. I am just surprised that it only lasts about a day, I would think a good battery even with alternator at 12.8 would still last longer.
Volt meter shows 12.8 with car turned off, with it running and also when turned off even with battery charger plugged in which I thought was odd, you'd think there'd be more with the charger charging it.
