1G Alternator Install Question...missing a bolt
flyinghighlm
345
4
Sep 27, 2005
charleston, South Carolina
Basically I have done a ton of work to the car and I have it about 90% done but when I went to put the alternator back on I noticed I was missing the bolt that goes to the Alternator Bracket Arm, you know the brace that the banjo bolt goes into to tighten it all down. The bolt in question is the one behind the water pump pullies, I thought it was 10X1.25, nope to big, 8 X1.25 nope to small....CAN SOMEONE PLEASE TELL ME WHAT BOLT THIS IS/SIZE AND THROW A PIC UP ON HERE. Is it a long bolt thats smooth with threads on the end or what?????
That's not the right one. That looks like the one that bolts the alternator to the block.
Morpherex said:
No, I think the one youre thinking about is thicker.
That one he is holding is threaded all the way. It should be smooth until about the last inch or so.
luv2rallye said:
8 x 65mm long (goes through water pump housing and is smooth with threads on the end). Picture is from a 2g but 1g should be same.
Dead on, thanks. Wish the forum's didn't go down right after I asked but oh well better late than never. Thanks, alot for the help.
