Alternator dead?
SlowChild3
545
9
Aug 19, 2005
Dayton, Ohio
I've got a new 90 amp alternator relocated. It has maybe an hour of run time. My voltage jumped to 15-18v. I actually have a log of when it took a crap. Could anything have caused this besides alternator regulator? I really don't want to remove the manifold again. Ugh...
OK now I need some help. Everyone I talked to said over charge could only be caused by a bad regulator. I had my alternator tested and checked out good.
Yes, you are correct. An voltage regulator can allow the battery to receive an extra load of current, overcharging the battery. By the looks like of the test results that the alternator is at 14.93 volts. Some people would like to have an alternator that outputs that extra voltage. I'm not sure if you have any other choice but; to replace that alternator with another if it is getting the battery too hot by the extra overcharging. 13.7 TO 14.1 is optimal for alternator output and they will of course vary in voltage.
Make sure your battery is FULLY charged then try your reading again. Go have your battery checked that could be the reason the voltage regulator is a little off the charts, trying to charge a bad/dead battery is something that will cause improper reading when checking alternator voltage output.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
  • For sale 4G63 SPAL 6.5 inch Low Profile Fan - Push
    SPAL 6.5 inch Low Profile Fan - Push $55 + shipping & paypal fees* these are great to use with...
