Almost got my new sub setup finished
Their shouldn't be any cancellation between the 15 and 10 right now, as the 15 is unhooked, I just need to tighten the airspace down to the correct size. I'm almost 100% sure i have almost double the needed airspace for the ported box.
I understand....I'm just saying that phase cancellation might be a serious issue once you get the 15 running again. Imagine flipping the "+" and "-" speaker wires on one of your 10's....those 2 10's would then be completely out of phase....It's a pretty distinct sound. You could have issues that sound similar once you get your 15 hooked back up.
Ok fellas, Ive been busy on getting the exact sound I want out of my 10s, and it has turned out phenomenally. I closed up the top ports, and relocated the ports to the bottom of the box facing the rear of the car. Now instead of having 1 3inch port I have 2 1.5 inch ports on each box. I also aeroport modded each one as well to get better spl out of them. When I did this i also dropped the airspace to about 1 cubic foot and tuned the ports to 40hz.
Sounds amazing right now with just the 10s, its significantly louder than when I ran a JL 15w3 in a slot ported box. I also picked up a new Pioneer headunit to match my color scheme that has a few better options for me. To finish it up I did my signature mod to my ports, which is putting green leds in them that flash with the bass. Super easy to do, but very few people do it.
Im just waiting for march to get my 15 now, its looking like im getting my JL repaired and upgraded by extremePSI and picking up a Power Acoustic amp that puts out 2200 RMS at 1 ohm. After that its just fiberglassing and it will be done finally.
