Air Intake Question
bsizer
Mar 29, 2006
Williamsport, Pennsylvania
Installed new air intake on my wifes 91 talon non turbo 2.0
totally new to dsm's so now I dont know how to fix the current issue
car will not idle, I can get it to run by unhooking the air mass senor
but it will not idle and is running very rich
Im guessing the fuel needs adjusted but I have no idea how to do that
any help would be appreciated
Was it running fine before? If all you added was the air intake, that's most likely your problem. Pull it back off and reinstall it. Make sure your not not leaking air anywhere and that your MAF is completely plugged in.
If you can't get it to run with the new intake, put the old intake back on and see if it fixed the problem.
