2G Aftermaarket throttle body question
what size throttle body are you looking for... you should just do a 1g throttle body swap there a lot bigger then the 2g throttle body
2g throttle body is 52mm and 1g TB is 60 mm. There are not really "aftermarket" throttle bodies for these cars just bigger stock ones(1g TB, you can bore out the 2g TB, q45 TB, mustang TB)
I would stick to a bored 2g or 1g throttle body if this is a street car. Remember that a larger throttle body wont do jack if you dont port match the intake manifold.
so after you do the 1g throttle body swap you minus well get a 1g intake but then again the ports on the 2g head do not match the 1g intake so you should just buy a 1g complete head with throttle body and intake..
IIRC Twicks69 was putting down nearly 1000hp to the flywheel on a stock 52mm throttle body.
There are far more important upgrade parts for our cars. Start by reading the upgrade path in the tech section, it will give you a great idea of where to start and what order to do things in.
