Throttle Body Question
94'TSI'AWD
189
May 2, 2009
central point, Oregon
Hi!!! My question is will a throttle body from a 1991 eagle talon FWD Turbo, fit onto my 1994 eagle talon AWD Turbo intake manifold? From what i can see on my throttle body is that i have 4 vacuum lines plugging into the top of it, while on this 91 throttle body it only has 2. So i am not sure what to do.. The screw on top of my throttle body is all stripped out and mashed....so i need to replace the entire throttle body....yay.....any ideas guru's?
Yes, it'll work. Not sure why it only has 2 ports though. Are you sure it's not a '90 and the other two ports are on the side? Or maybe someone pulled the other 2 out?
How do you know the screw is stripped? If you're trying to unscrew it out, it won't. It has to be pushed out.
It is the idle adjustment screw on the throttle body, mine is destroyed, so the idle is going INSANE, but even if it isn't the culprit of my idling woes, at least i have peace of mind knowing that i replaced that gnarly looking conglomeration of stripped out metal. I will post some pics tomorrow of both Throttle body's and you guys can decide which looks better!
I think hes saying that the threads in the throttle body are stripped, not the biss screw.
I have yet to see a throttle body with stripped threads. The head of the screw might be stripped since the 1g's had metal screws. All you need to do is extract the old screw (easiest to do from inside the throttle body) and get a new BISS screw and BISS o-ring.
Here are the pics of both throttle bodys so you guys can see what i am talking about.
this one is on my car still and i circled in ted were the striped out screw is..
and this is the one from the 1991
what do you guys think?
The 2nd picture is a '90 throttle body. The one on your car is a typical '91-'94 throttle body.
I still want to know how you're sure the screw is stripped out.
Do you mean the threads are stripped? If so, how do you know? If the screw is just spinning in there and won't come on, this is normal.
If the head of the screw is stripped, that's another easy fix.
NO i cannot get the screw to spin at all in either direction, It is (from what i can see) Just the top of the screw it is like this but a little more smooshed.
and they guy told me that the throttle was from a 91...so he just wanted to make a quick $40 huh?
+1 or you might try a small chisel. I think the metal ones are a softer lead or brass if I remember right. Before you drill a hole and use the extractor try a chisel and punch it and see if it will get a bite.
Kolby
