after swap it just wont start! need help
infamouscody
Oct 23, 2006
bradenton, Florida
ok, heres what i did, i have a 94 eclipse that had a 1.8 NT auto trans and that motor blew, so i just swapped a 2.0 NT manual trans into it. i swapped the ecu and the front half of the wire harness (from the ecu to the engive bay) everything is plugged in and it turns over and almost starts but it just wont crank up..
-should i swap the dash harness as well?
-i know your supposed to "trick" the car into thinkin its in park, but everything i read, the wire harness was never swapped. the harness i put in doesnt have a plug that i have to "trick" because the harness is meant for mannual trans.
im not getting spark so my thought is the car doesnt know its in neutral, \
is there a neutral safety switch somewhere that i need to mess with or am i supposed to plug something in to the clutch pedal?
is the harness in my car the same for a manual and auto?
any help would be appreciated, this is my daily driver and i just lost my job because of this! thanks,
cody
its not getting spark, whats the best way to check though? and my fuel pump isnt coming on either when the key is in "on" position, but i tried using starter fluid and also wiring the fuel pump directly to the battery and then tried starting it... i just dont know, i put soo much work and time into it i dont wnna sell it and give up, any one live in florida that would like to come over and help out a fellow dsm'r? LOL
cody
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
