After market Sandwich adaptor??? Thoughs?
I have something similar on my 1G. not exactly the same but still an ebay adapter. It's worked pretty well so far without leaks or any other p.i.t.a. issues.. I'd say go for it.
Did you have a problem fitting it in there without interfering with the 02 housing?
Just saw the glowshift website, which adapter size should I get?
1. 20mm 1.5 Thread
2. 3/4 unf-16
3. 13/16-16 Thread
or
4. 18mm 1.5 Thread
never mind they have Vehicle Specific Oil Filter Sandwich Adapters
My only concern with oil adapters, for hooking up oil coolers is does it have a provision for an oil temp valve. These open to let the oil into the cooler like the stock unit on a 90 1g . Otherwise you are cooling your oil the entire time and it may not need it.
