2G AFR and idle changing when braking or headlights on.
Maple guy
May 6, 2026
Loudon, New Hampshire
So I recently purchased a 97 Eclipse GSX. My AFR was acting up. Did a leak check and found 2 sizable leaks. Fixed them and AFR is still not right.
Attached is a video I just took after discovering my idle and AFR changes when I press the brake which I know can be a brake booster leak however AFR and idle also are affected when I turn on my headlights or fan for heat.
Any input is greatly appreciated.
