AEM water meth to EMS 30-6300
bu3bu3
55
Jan 20, 2008
Columbia, Maryland
Hello everyone.
I need help with hooking up the AEM Water Methanol system to EMS 30-6300. Which wire goes to where and how can I sync both of them to run in a perfect harmony I have not contacted AEM yet but I know there is someone out their knows how.
thank you.
Ok but where should I connect the Green, and the Blue wire to?? thank you.
The blue wire is almost like a splice off of the boost pressure sensor. It will output a 0-5v signal based on what the pressure is at the sensor.
EX.) 75psi sensor - 0-5v - at 15psi it will output 1v and at 45psi it will output 3v etc.
The wire is used for any other modules that need to read a pressure sensor.
Green wire is optional and wont be needed.
