Archer Fabrications
- 9,719
- 706
- May 9, 2011
Scottsdale,
Arizona
Hey guys, I have an AEM oil pressure gauge (I didnt install it) and it has been working fine until yesterday when I turned the key to the on position the gauge was swinging at 150psi to 100 psi back and fourth. This was with the engine off so I know there wasn't even any oil pressure.
I know it does a check when you first start up and goes from 0-150 and back down to 0 then to your oil pressure when the car is started, and it does work when the car is started, but I found it quite weird that it was swinging from 150-100 back and fourth as soon as it hit each number would go back to the other.
Anyone else have this issue? Could it be one of the serial cables in the back might be loose? I'm just hoping that this doesn't mean my gauge is reading inaccurately.
Also when the shop installed this gauge my stock one was disabled. Any way to have both and how do I get it to log in ECMLink?
