aem fuel rail
eclipsekid1013
162
May 9, 2010
hudson, New York
hey i found an aem fuelrail with 450 injectors fr 40 bucks i have a 4g63 na can i use the aem rail with my stock injectors and just sell the injectors or is the rail diffrent for na and turbo
Stock fuel rail is good for at least 700hp. Unless you are using E85 and need a lot more flow then the stock rail is safe. Especially seeing as most aftermarket rails are right around the same size as the stocker.
I would not bother with the rail...if anything replace your pump with a walbro 255 and your reg. with an afpr. will set u up for success down the road
Not a bad price though i'd buy it keep the injectors for later and sell the rail for 40
Then again, the car is non turbo. Why do you need more fuel? You need more air pumped into that motor, not fuel.
