AEM Fuel Rail / Fuel Injector O-Rings
usmc0651dns
209
Jun 3, 2010
Monticello, Kentucky
I was taking the fuel rail off to change my stock injectors to a set of 850's. I seem to have dropped and can't find two of the spacers between the fuel rail and the block. Is there a place to buy these or should I just go to the parts store and show them the one that I still have? Also since I will be running bigger injectors should I go ahead and try to get an AEM fuel rail? I think it uses and includes different spacers also.
Pretty sure the phenolic spacers are an OEM only part. Check the runners of the intake manifold and the support bracket under it. Might have fell on the subframe too... I usually find them hiding on the intake manifold somewhere right in front of my face though.
I wouldn't worry about a fuel rail upgrade unless you're running a -8AN feed line.
Guess I'll pull out the MAG lite and actually look for them :pray:. I'm pretty sure it has the stock lines since it was a stock fuel rail. I was just wondering if it is a good idea when bumping the injector size up 400cc.
If you have a account on dsmtalk there is a pay it forward thread on there and im sure someone has some spares they can mail you. GL finding them!
