Fuel Injector Clinic Fuel Rail
wt71gas
144
4
Oct 15, 2004
Auburn, California
I recently purchased a Fuel Injector Clinic fuel rail. I was wondering if there was anyone else out there that has one and has the same issues as myself. The first is that the spacers that ic comes with are not the right length so I had to add washers to get the injectors to seal right. The second issue is that the flat bottom piece did not have enough clearance to get the injector plugs on so it had to be notched with the grinder. I would assume I am not the only one with this problem but I couldn't find any other threads in the search.
If you look at my profile you will understand why I am running an aftermarket rail. As was stated earlier you need to be making a lot of HP to need a rail so why would a company not make their rail fit the vehicle with the aftermarket injectors they sell????? That is all i'm asking. And I was also asking people who have these rails if they have had similar issues or if I just have an older design
