ECMlink AEM 5 bar map sensor
NOSLO2PT0
2,686
250
Aug 31, 2002
Joliet, Illinois
What’s the difference between these two sensors, other than a brass body vs Stainless steel?
Where can you buy a complete pigtail for the 5 bar map sensor? I see eBay/Summit sells the connector, but it doesn’t come with wiring/pins. Is there somewhere to get the pigtail without buying the sensor?
If you buy a new sensor, it comes with a connector and pins. If you get an used sensor or if you are lazy to assemble it by yourself, you can use a pigtail for a LS1/LT1 TPS, it's the same connector.
Like the one in the link below.https://www.ebay.com/itm/161978155333
Thank you. Didn’t realize they were the same.
