AEM Need wiring instructions for IAT sensor and 5 bar map sensor.
Turbogsxmitsu
40
Feb 22, 2003
ridley, Pennsylvania
Hey everyone, I'm getting ready to get my AEM in my 99 GSX and I just bought an AEM Intake air temp sensor and an AEM 5 bar MAP sensor. I need instructions on what wires I need to tap into to hook these hooked up correctly. I know the IAT sensor hooks into 3 wires on the MAF harness, but I need specifics. Also does the MAP sensor wire directly into the stock MDP sensor harness?
Id appreciate everyones help, thanks in advance. :thumb:
IAT sensor hooks to 2 wires on the MAF harness.
5 bar MAP hooks to the 3 wires that run to the stock MDP sensor on top of the intake manifold. I'll find the wire colors and report back. :)
Go to www.vfaq.com and click on electrical and select 2g ECU pinouts.
You want pin number 72 for the intake temp sensor. The sensor is a bi-directional sensor so either wire can go to the sensor wire. The other wire goes to a ground. (look under the dash for the color of the wire in pin 72, then go on the MAF harness and tap into that wire.)
MDP sensor uses pin number 73. Same thing, go under the dash, find the color and go to the harness in the engine bay. That wire is the sensor wire, the black wire is the ground and the other colored wire is the power. Just use all 3 wires for the MAP sensor.
If you have issues and can't find the colors, or if no one posts it by tomorrow, I'll take a glance at my car and post them up! :)
