420A adding fluid to the manual transmission
Lol, oddly enough I have seen this question a few times. While Gofer gave you the official fill spot, many use the reverse plug to fill her up (its located toward the nose of the tranny, a little below the tranny mount). Let me see if I got a picture in here. Here it si;
Its the little plug (with blue on it) toward the end of the tranny. You disconnect that plug and then just unscrew the sensor.
MB
MB
if he is just topping it off,how will he know if he is at the right level if he fills it from the top.is it bad to over fill?I usually put the trans fluid in a lucas squeeze bottle.then I get a 3"long hose to fit in the side hole.put the bottle to the hose and start squeezing.:hellyeah:
It's a pain to fill through the same hole that is supposed to indicate level. It doesn't matter where you fill it from, as long as it's above the "official" fill hole and you check the level through the "official" fill hole.
I fill mine every now and then ( 5 speed) but i remove the battery and tray, gives me easy acces to drop the hose dow and let gravity do the work.. fill it untill it overflows then you re done.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
