act 2600 street disk problems??
toolegit86
35
Apr 4, 2009
Benton city, Washington
ok so i have a 95 talon and it has:
Fidanza fly-less than 2,000 on and not raced
ACT 2600 street disc-less than 2,000 on and not raced
new shift cables with roller bearing in the end
SS clutch line
new Master Cyl
New Slave Cyl
New pivot fork and TOB
now after just driving it on the free way at 65-70mph it will not shift...
when you you try the motor dies down and the clutch makes a weird sound and it will not go into gear?? when i parked it it was fine then when i went to move it again it would not do anything. i replaced the slave cyl again cause the new one i got was already leaking. and the master is still new? i see that the clutch fork is still moving so i have no idea?
no how?? i did not even look at that? but i see that the slave and clutch for still move as much as they should?
ok so i messed around with it and still no shifting... the fork moves fine and i adjusted the pedal i see that the fork is moving fine but it looks like the throw out bearind is not pushing flat. and it looks like it is jsut resting on the pressure plate??
any ideas??
any ideas??
It should not be resting up against the pressure plate. Remove the Slave and see if you can wiggle the fork left and right with your fingers... you should be able to.
If the TOB is not pushing flat then you got a problem, can you explain what is happening with the TOB? The clip may be loose of the TOB may be toast. Hard to say without seeing it for myself.
Tom
yea you can still move it. i am going to pull the tranny and see if the TOB is still attached to the clutch fork.
