slickers111
- 1,302
- 0
- Apr 30, 2009
Sheboygan,
Wisconsin
I recently bought ACL main and rod bearings. The rod bearings are ok, and match up to my old ones. however, the main bearings, specifically the thrust bearing, is different.
I did a little research on it and came up with this.
My old ones have the washers built into the bearing. The kit I was told will fit exactly has the washers separate.
Do I need to go back and swap out for the right bearings, or will the washers fit my set up?
I dont see how the washers will stay in the right spot to be honest.
You need to check the year of your block and use the main bearings for that year. Some 7 bolt blocks use a saddle bearing for the thrust. A saddle bearing has the thrust built on the main bearing.
Other 7 bolts ran a main bearing and thrust washer set up
