ACL Bearing Thickness
aspekt9
344
4
Dec 25, 2005
Boston, Massachusetts
Does ACL list their bearing thicknesses or have a chart? What is stock size bearing thickness?
what ACL bearings? stock? or race?
even the race bearings are made to the stock diamentions, so the stock Mitsu bearing clearances apply
Race bearings, I'm looking for the thickness in inches of the bearings. Or should I just see if the oil clearances fall within OE spec and then just assume std. size bearings will be the correct size?
has the crank been ground undersized? or just polished?
if you have a std shaft, get std bearings, if the crank has be ground .010/.25mm then get the proper sized bearings
