Lancer_lover
- 181
- 60
- Apr 18, 2017
kristianstad,
Europe
I got the Ac belt 925 mm and it doesnt fit !! It is a speciall way to put it on ?
I find it easier to remove the 3 12mm bolts for the bracket, slip the belt onto the compressor and crank pulley. Put the tensioner at the lowest setting. Put the belt over the tensioner pulley and put the 3 bolts back on. Idk if that’s the right size or not.I got the Ac belt 925 mm and it doesnt fit !! It is a speciall way to put it on ?
Stock belt is 945 according to rock autoI got the Ac belt 925 mm and it doesnt fit !! It is a speciall way to put it on ?
Really ? I gonna check it out I live in Sweden so parts is something i got to orderStock belt is 945 according to rock auto
The bracket is removed but i cant get the belt on dont know if the belt is to Short :/I find it easier to remove the 3 12mm bolts for the bracket, slip the belt onto the compressor and crank pulley. Put the tensioner at the lowest setting. Put the belt over the tensioner pulley and put the 3 bolts back on. Idk if that’s the right size or not.
