a/f gauge dont move stays at rich
girlpower92
147
Mar 24, 2005
perry, Ohio
ok i hooked my a/f gauge up to day and it has 1 bar that stay at the bottom of rich and never moves
things i think it could be
crapy o2 senser i need to repalce wires look pretty bad on it
not geting alot of volts to the gauge i hooked it up and it looks pretty dim
thats about all i can think off i hooked it to pin 4 of the big conector on the ecu in my 1g fwd 5spd tsi thanks for the help
probably because its inaccurate and a peice of junk. A/f gauges are mostly for show, they really don't do much except give people seizures or make the passenger say hey whats with the flashy lights? although yours isn't flashing all different colors, so maybe your lucky.
What did you use to connect the wire to the o2 sensor? I had the same problem and I checked my connection and sure enough I wasn't having any sort of metal to metal connection when I crimped the wires together. :thumb: :talon:
exactly what happened to me, just re-check the connection. as for the accuracy of them mine is all over the place b/c i have a huge fuel problem im trying to fix but my friend has the exact same gauge as me but his is pretty accuate in telling him how his fuel is doing. i took his car out for a drive the other day after fixing it and was cruising at 1/2 throttle and the gauge was still at dead center led. so i dont know, its just my .02$
Unless its a wideband AF gauge, Im willing to bet its not as accurate as you think. Maybe close, but I wouldn't get worried when its not right, and definitly not use it for ANY kind of tuning...
why would you connect it to a fog light? unless i misunderstood that, i connected all of mine at the ecu. the signal wire is a white wire on the 4th plug of the ecu (with your left ear pointing towards the floor mat 1 is the lowest one and 4 is the top most one) the pins on the 4th one start at #71 (top left) and you connect it to wire in pin 76. ill try to find the write-up on that.
-steve
no i used the wire from a fog light i had laying around they were new wires and i hooked the a/f gauge to pin 4 in the ecu power i grounded to a bolt on the side around were the ecu is and power i hooked in to a fuse it lights up but just dont move no techno lights show LOL i dont car if it acruet i just want to kinda know whats going on
