cswindel
- 353
- 576
- Jan 13, 2023
Georgia
Alright electrical nerds I need to be graced with you assistance as I am no good with electrical.
Current situation:
- A/C is not blowing cold air although the system has been charged recently without the system actually pulling in r-134 because well it dont work haha
- I dont have any prior knowledge of whether it worked or not before or after my teardown of the car
- As a side note I am running OHM harnesses throughout the engine bay and interior and running ECMLink v3
Current untested areas and possible theories:
- A/C compressor is dead and I have not ran 12v power to it such that I can test if the clutch engages or not
- Seeing if there is a setting in ECMLink that I am missing since the a/c and rad fan both kick on when signal for rad fan to kick on gets pushed out
- Thermo sensor is poop but havent checked and the wiring diagrams confuse me on where it is physically located behind the glove box and there arent really any pictures when i look.
- ACCU is poop but havent checked and not sure which wires in the connector to check but havent dug into that area yet because its a pain to reach
Steps I have taken thus far:
- Checked continuity from ECU pin 22 to A/C compressor relay in fuse box (Good continuity)
- With key in ON position and engine not running, I have voltage going to the a/c fan (connector A-39), Dual pressure switch (A-47), and the A/C compressor (A-95)
- With the engine running I checked for voltage at the same connectors and nothing concerning
- With the engine running and a/c switch active I checked voltage again and still nothing concerning. A/C compressor ground showed grounding too.
- With the engine running, I jumped/bypassed the dual pressure switch and no result came about from that
- As mentioned prior, I noticed that the a/c fan and rad fan kicked on at the same time when the signal for the rad fan got passed through the circuit (I dont know if this is normal or not but hey 2 fans is better than 1).
Just wanting to see what your inputs are with this matter before I start going down unnecessary rabbit holes without much guidance (because I will get lost, sad, and confused and it might all occur simultaneously). I believe I have covered the majority of what I have done and assessed to get this thread rolling at least
Current situation:
time dryer is fried for sure. I concur with previous posts on dryer and expansion valve. Ac isn't hard but it's tedious.
