99 gs turbo conversion help
ekizenbe
89
May 21, 2005
stony brook, New York
today i was put into contact with a friend of my pops who has just finished turbo'in his 99 gs its a 2.0 with the timing belt on the passenger side. so what do i need to do to the ecu, i believe he put in 450's but im not too sure yet, i have yet to see it but, he needs to know what his options are for fuel control. anyone know????
You do nothing to the ECU, unless you are going with MS. He will also need an FCD or ML installed.
The cheapest, easiest, and most popular way to control fuel for boost on a 2gnt is to use a 12:1 FMU for stock injectors, or an S-FMU for larger injectors.
He could also add extra injectors (8 injector setup) and run a 034efi or Portfueler controller. This is not inexpensive, though. MS (or MSnS-E) does beautiful things, is not expensive, and is usually the best option.
FYI: With stock internals, don't run more than 5psi without an intercooler, and 8-9psi with an intercooler.
and if you boost 15psi you start to blow oil pump seals and such... i got all my turbo kit from hahn racecraft they are very helpful when it comes to 420a turbo conversions...
So is the right forum....
There is almost nothing you can do with the stock ecu that is conducive to boosting the 420a. If you want to run 450's from a dsm you will need a resistor pack(unless you run msns) and a sfmu.
Search the NT forum and you will find all your info.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
