420A 98 Eclipse RS oil on spark plug boot
that spark plug is probably loose. Oil in the combustion chamber is getting past the threads into the spark plug hole. Now, is it alot of oil? Do you burn oil? Oil is normally present (vaporish) in the combustion chamber to be burned, but alot of oil suggests a couple of things like valve seals, guides, rings, PCV.
Alot of oil no not alot ...no smoke comin out my exhaust ...whatever it is it's just in that one cyclinder maybe the valve gasket ring
THANKS FOR THE RESPONSE
Valve cover gasket is probably bad (Spark plug well gaskets).
A little oil in the plug well shouldn't have any effect on how the car runs. The plug wire boot should fit snug enough around the plug where it won't even reach the terminal
