oil on spark plug
lou schmouder
271
Jun 17, 2008
dalton, Georgia
ok got some oil on my spark plugs. did a compression test 150 148 145 150 and did a boost test went fine. what could it be????
Well the first thing i would check is your intercooler piping and see if there is oil in there. If so check the turbo. If not i would then be thinking valve guide seals, or bad oil rings on the pistons. Other possibilities are the galley gaskets on the valve cover or a leaking headgasket.
dam he beat me to it... just like ^ said...!!!
well compression is good so I think the head is ok fresh rebuild with new rings and boost test check out ok so i think the valve seals are good
oil on the electrode side? if its pooled in around the plugs you will need to buy a new valve cover gasket set and replace the 4 seals around the plugs this means pulling the valve cover off
