mplacek27
- 0
- Nov 15, 2008
belle vernon,
Pennsylvania
i have a 98 eclipse that is making 16.5 volts at idle and 18 volts revved. the battery was checked and it is good. all grounds are good. alternator was tested and it is also good. the alternator on it is not volt reg in the alternator. i was told it is regulated in the ecu but if you go to advanced or napa they sell a voltage reg for it dunno where it goes though. it has a hole and brushes in it. not sure what to do. after bout 5 min of running at this voltage the water in the battery boils and blows the caps off
