97 GSX ABS elimination?
awdtalon4451
521
Aug 23, 2007
Ocean springs, Mississippi
Ok Just to fill you in on whats going on im swapping a 6-bolt into a 97 gsx. I bought a motor from Japan, bought a 2g tranny and trans yadda yadda LOLBoth body harness and engine harness were cut clean off by the guy i bought the rolling chassis from. He no longer has the main fuse box or the engine harness. So being that i had some parts left over from my 95 Tsi Awd im going to "try" to use the body harness from my 95. There is a difference between the two because the 97 has ABS and my 95 doesn't . How do i compensate w/o ABS on my 97 in a safe way? can i use my 95 body harness? Will removing ABS on my 97 hold me up later on when installing my motor? Exactly what should i expect from removing it?
Everything will act normal. the only thing is you may have a abs light when you put everything together, but not a 100% on that.
