2G '96 Talon TSI Alternator Not Charging
1slowhatch
172
Mar 5, 2014
Reno, Nevada
Recently got the car running. Purchased it with a broken timing belt. All new timing components, seals, cas, etc. Car runs and drives well, idles smooth, no check engine lights... however, it appears the alternator is not charging. I did have an alternator warning/battery light on first start up with the head. I noticed the positive terminal on the battery was loose, so I replaced it. The light went away. I assumed everything was fine. However, I have checked the voltage at the battery and the output stud of the alternator with the engine running, I never see more than battery voltage (high 11's to low 12's). The battery is approx. 2 years old and has passed a load test.
What could this be? The alternator itself looks like it couldn't be more than a year or 2 old. It is plugged in, the charging output is tight.
Any ideas? I still can't get it to charge. Tried bypassing the charge wire with jumper cables, added a ground to the alternator. Had the battery warning and A/T temp idiot light on for a minute or two today, then went off.
I believe I have this solved. I swapped out the alternator for a 90 amp reman unit and it appears to have fixed the problem. 14v+ at idle now, no more dead battery, haven't seen the battery warning light in a while.. I do have a check engine light.. P1400. It also runs a bit "jumpy" in the mid RPM range while driving. I've read this can be caused by a bad MDP sensor, but more commonly a boost leak problem!? I double checked that all the intercooler plumbing is hooked up and tight, checked for loose vacuum lines, etc. I do think that the factory BOV is leaking much earlier than it should, could this be causing the problem? When foot braking the car, I can clearly hear a boost leak, which sounds like the BOV releasing air after I see boost "come up" on the factory gauge.
