96 eclipse rs injectors
Ty Mason
Dec 23, 2017
Richmond, Virginia
i just replaces my injectors because my old ones were stuck in the open position. It was running prior to changing them out for new ones but now i have the new ones in and the motor cranks but doesn’t turn over. Any suggestions
is your fuel pressure within spec? are you getting spark?
where they all stuck open? how did you determine they were stuck open? cause changing the injectors wont help if you have a short to ground between the PCM/ECU and the injector
I got a friend of mine to call plug in his obd2 computer and it just said 3&4 were stuck open and I’m not sure about the fuel pressure. I know I’m not getting fuel pressure because the Schrader valve wasn’t releasing anything but i don’t know what cause my fuel pressure to drop.
check the ASD and fuel pump relays, they are on the firewall next to the brake fluid res.
And my friend said that my computer might not be recognizing the new injectors how likely is that and how do you reset the computer if that is the case
As long as you put the correct injectors back in, you don't have to do anything with the ECU. The ECU also will not throw a code that says the injectors are stuck open. It would throw a code for a rich condition if the motor would even run.
Check and see if the fuel pump is priming when you turn the key to the on position. It should turn on for a few seconds
Yes the fuel pump turns on
