95 talon project car
lee07
Feb 22, 2010
belleville, Wisconsin
I am in the process of building a 95 talon to race at one of the three local asphalt circle tracks in my area. Last year I raced a probe and it's the car to beat because of the width and handling of the car even though it has a lot less HP than the Nissan and neon. No one has tried to run a talon and I'm very excited to prove it will work even though there are a lot of nay sayers.
The roll cage is almost complete (6PT cage) and the rear strut towers I tied into the roll cage. when thats done I'll be working on the suspension. this could be a challenge (no coil overs track rules). the only other rule is 4.5"min. of ground clearance.
Your not supposed modify your engine but everyone does. I was planning on porting and Polish my intake manifold and opening up my exhaust followed by a Dino run and air/fuel mixture adjustment. I did this to the probe and gained 14hp but saw a 19hp gain when i put different cams on.
I hope to post some pictures as I make more progress. Any ideas, comments, suggestions I'm open to this is my first attempt at a forum and hope I'm not doing about this wrong.
THANKS
(This is a non turbo class)
You should have used a N/T convertable seeing the success of the KBR Time Attack eclipse, and all of the technical reasons behind its superiority over the coupe for front wheel driving. Also it has the 2.4 4G64.
convertibles are prohibited. As far as the choosing of the talon i was looking on line for performance parts for various cars and there seemed to be an abundance of parts for the eagle/Mitsubishi
