TC1995
- 35
- 31
- Aug 27, 2024
Raleigh,
North Carolina
Trying to save this 1995 manual GSX no sunroof VIN# 0001995 car.
What I know so far, (134,xxx) miles and that the car sat open to the elements with busted driver window for at least past 8+ yrs. It was in an accident obviously and never repaired. Allegedly it was running and driving when it was brought to a shop for repairs. That's basically the full extent of what we know.
I plan to rebuild everything myself, I've had two '95 GSX so I'm decently familiar with the platform but that was 15yrs ago. My goal is to rebuild the car properly (doing necessary things for longevity, rust remediation, prevention, updates etc) to keep it forever as always regretted selling previous ones.
My #1 priority currently is that I want to get the car running and moving under its own power before anything else to fully stress test systems before a full rebuild and teardown.
With such an unknown basket case and sitting for so long I want to see what everyone's thoughts are on priorities to tackle first or in order. Generally this is what I'm thinking right now.
1. Clean everything. Remove debris, dirt, leaves, spare parts, extra wire and cap wires that might be live from hack job splices into harness etc.
2. Document what modifications I can identify such as the A'PEXi controller, turbo, intercooler, any ECU stuff etc.
3. Did already sort of see that engine is free as it seemed to have some compression while in gear rolling vs not in gear.
4. Need to check all fluids (already saw that oil is in there and darker but no immediate red flags)
5. Camera scope all cylinders, intake intercooler, turbo, gas tank, radiator etc.
6. Get a battery and see if we have any power, ensure fuse boxes are getting power, inspect all fuses and relays. Not sure if I should disconnect fuel pump before giving power in likely scenario that crud is in the tank.
7. Provided most things are getting power Code read the car to see if I can glean any info from any past stored codes or history of the car at all.
8. Pull and bench test starter and ignition system, get new plugs and maybe wires
9. Drain gas tank and change oil and other fluids as needed.
10. Test fuel pump and lines, run fresh gas from auxiliary tank if this one is gone
11. Lube oil everything and try to crank?
Definitely missing stuff but this is first draft of what I'm thinking
These cars can be such a pain, but when they run right, man do they sound beautiful....
