General 95 EPROM ECU in 97 GST.
Siral3x
299
Mar 2, 2006
Ludington, Michigan
I know this question has been asked here before however I get mixed answers.
1.I know the CAS signal is inverted so I need to swap plug wires;
2.I have read about random misfires that can be cured by swapping injector pins at ECU?
Does anyone know which inj wires/ones need swapped at ecu?
I have no intention of buying DSMLink as I can burn my own chip.
Thanks in advance!
I don't think you need to swap injector pins and as for the random misfire, if you don't have link you just have to turn the car off and turn it back onto make it stop missing. And you are right about the inverted cam signal and plug wire swap.
